Mi permetto di fare un doppio post dato che gli argomenti non sono correlati e si tratta delle prime sugose news e sugose carte (chiaramente improponibili in t1) che gli spoileratori per eccellenza ci offrono... per chi non sa attendere ecco 5 carte con link per le immagini
Wrens Run Packmaster (Prerelease giveaway)
3
Creature- Elf Warrior
5/5
(Rare)
Champion an elf (when this comes into play, sacrifice it unless you remove another elf you control from the game. When this leaves play, return that card to play.)
2: Put a 2/2 green wolf creature token into play
Each wolf you control has deathtouch.
http://forums.mtgsalvation.com/attachme ... 1187737703
Epic Proportions
4
Enchantment- Aura
(Rare)
Flash
Enchant Creature
Enchanted Creature gets +5/+5 and has trample.
From mite to mighty.
http://forums.mtgsalvation.com/attachme ... 1187737711
Fodder Launch
3
Tribal Sorcery- Goblin
(Uncommon)
As an additional cost to play Fodder Launch, sacrifice a Goblin.
Target creature gets -5/-5 until end of turn. Fodder Launch deals 5 damage to that creature's controller.
Leave it to a Boggart to come up with a projectile as disgusting as it is deadly.
http://forums.mtgsalvation.com/attachme ... 1187737722
Fallowsage
3
Creature- Merfolk Wizard
2/2
(Uncommon)
Whenever Fallowsage becomes tapped, you may draw a card.
Memories of ages past are said to swim the minds of lounging fallowsages.
http://forums.mtgsalvation.com/attachme ... 1187737737
Galepowder Mage
3
Creature- Kithkin Wizard
3/3
(Rare)
Flying
Whenever Galepowder Mage attacks, remove another target creature from the game. Return that card to play under it's owner's control at end of turn.
http://forums.mtgsalvation.com/attachme ... 1187737750
Questo è quanto.
Ora
non credo si possano giocare in t1, ma ripeto, le immagini sono belle e le meccaniche anche. Epic proportion è ciò che un giocatore di limited vorrebbe sbustare (insieme a damnation) per il suo mazzettino, e l'elfo promo lo si cala isi di terzo in constructed...
l'unica carta che mi sembra davvero interessante è il merfolk, anche grazie alle nuove meccaniche come convoke e rescue può essere carino, sempre parlando di formati wiz....
Le lacrime di Chuck Norris curano il cancro. Il problema è che lui non ha mai pianto."
Adamo aveva il pomo di Chuck Norris.
L'universo è in espansione perchè sta tentando di fuggire da Chuck Norris.
