Oggi è mar 12 mag 2026, 8:33
Scrivi un nuovo argomento Forum bloccato Pagina 1 di 1   [ 8 messaggi ]
 Oggetto del messaggio: Calice del nulla + Stifle
MessaggioInviato: dom 2 dic 2007, 23:02
[card]Chalice of the void[/card]
[card]Stifle[/card]
Quando il calice entra in gioco è possibile stiflarlo in modo che non ci vengano messi segnalini sopra?
fase 1: Trova tuo cugino
fase 2: Metti tuo cugino nel cannone
fase 3: Trova un altro cugino
"I am Stephen Menendian,Don't u know that?"
MessaggioInviato: dom 2 dic 2007, 23:12
[card]Chalice of the Void[/card]
Text: Chalice of the Void comes into play with X charge counters on it.
Whenever a player plays a spell with converted mana cost equal to the number of charge counters on Chalice of the Void, counter
￾ To have it come into play with 3 counters, X must be 3, which means you have to pay {3}{3} or {6} mana. You pay twice of whatever value you want X to be.
￾ It only checks the number of counters on this card at the time the spell is being played. Changing the number of counters after that will not change the outcome.
￾ If it has zero counters on it, then it triggers for spells of cost {0}.
[card]Stifle[/card]
￾ An activated ability has a "Cost: Effect" format. Look for the colon. A triggered ability starts with "when", "whenever", or "at".
￾ It can target delayed triggered abilities. For example, a card that says "Whenever a player cycles a card, you may remove target creature from the game. If you do, return that creature to play at end of turn." triggers when a player cycles a card and creates a delayed trigger that happens at end of turn. You can choose to target the "at end of turn" trigger when it is placed on the stack at end of turn.
￾ Game actions like the normal card, combat damage, or turning a face-down creature face up cannot be targeted
Quindi penso di no. Non puoi stiflare i segnalini che vengano messi quando entra in gioco, poichè sarebbe un costo di lancio.
Puoi stiflare se metti in pila La magia che vuoi lanciare e poi stiflare la triggered di chalice per quella magia attuale.
Esempio: Chalice a 2
Gioco oath e poi faccio stifle su chalice in risposta alla sua trigger.
Dovrebbe essere corretta così, penso.
† Ogni tanto ritornano... †
MessaggioInviato: dom 2 dic 2007, 23:32
Confermo...............
La vita è decisa da un welder...Cè chi sta in gioco e c'è chista nel cesso!!!!
MessaggioInviato: lun 3 dic 2007, 1:23
Che sarebbe un costo di lancio?
In realtà non puoi stiflare la messa dei segnalini sul calice, in quanto si tratta di abilità statica, e quindi non di innescata o attivata.
MessaggioInviato: lun 3 dic 2007, 15:59
No Kalle intendevo che i Segnalini messi sul CoTV quando entra in gioco , sono di un abilità statica... ma non è considerato anche un costo di lancio?
MessaggioInviato: lun 3 dic 2007, 16:18
Il costo di lancio è un termine obsoleto per indicare il costo di mana di una carta (ossia il costo indicato nell'angolo in alto a destra della carta).
Il calice ha come costo di mana XX, che varrà il mana speso quando il calice è in pila e 0 in tutte le altre zone.
La prima abilità del calice è una abilità statica che modifica la maniera in cui il calice entra il gioco. Nello specifico lo fa entrare in gioco con X segnalini sopra, dove X è pari alla metà del mana speso per giocarlo.
MessaggioInviato: lun 3 dic 2007, 21:55
Ecco risolti i dubbi, comunque alla fine è come ho detto io >.> non puoi stiflare i segnalini al momento che entra in gioco, ma puoi stiflare la triggered se giochi la magia al costo indicato. Ovviamente se il chalice è a uno, ti salvi solo con trickbind.
MessaggioInviato: lun 3 dic 2007, 22:14
Avere dubbi è lecito e siamo qui per chiarirli.
Per rispondere a domande di regolamento in questa sezione non è consentito avere dubbi.
La parte della tua risposta che ho corretto era appunto non corretta, per essere tale avrebbe dovuto essere precisa sia negli effetti che nelle cause.
Non è la prima volta che ti riprendo in questa sezione sempre per questo motivo.
Che questa sia l'ultima, alla prossima scatta il warning.
Lock
