Oggi è mar 13 ott 2026, 4:42
Scrivi un nuovo argomento Rispondi al messaggio Pagina 1 di 2   [ 23 messaggi ]
 Oggetto del messaggio: Ancestral Vision
MessaggioInviato: ven 25 gen 2008, 13:09
Volevo sapere innanzitutto se potevo imprintare Ancestral Vision col Panoctic Mirror e se si' come poi funzionava, cioè se attivando il mirror posso pescare 3 carte bypassando il problema del suspend o cosa succede?
Ancestral Vision:
Info: Color=Blue Type=Sorcery Cost=None TS(R)
Text(TS): ~this~ is blue. ; Suspend 4 - {U} ; Target player draws three
cards.
This card is blue in all zones. See Rule 402.8a. [D'Angelo 2007/06/04]
Since this card has no mana cost, it cannot be played as a spell. It can
only be played using the Suspend ability. [D'Angelo 2006/10/08]
It can be played if an effect allows you to play a spell without paying its
cost. See Rule 203.1b. For example with Mind's Desire.
[D'Angelo 2007/10/20]
Panoptic Mirror:
Info: Color=Artifact Type=Artifact Cost=5 DS(R)
Text(DS): Imprint - {X},{Tap}: You may remove an instant or sorcery card
with converted mana cost X in your hand from the game. (That card is
imprinted on this artifact.) ; At the beginning of your upkeep, you may
copy an imprinted instant or sorcery card and play the copy without paying
its mana cost.
You can, as an activated ability, "imprint" a card by removing it from the
game and paying {X} mana. You can have more than one card imprinted
at one time. [D'Angelo 2007/03/25]
You do not play the imprinted spells, instead as a triggered ability at the
beginning of your upkeep, you pick one of the imprinted spells and play
it for free during the resolution of the triggered ability.
 Oggetto del messaggio: Re: Ancestral Vision
MessaggioInviato: ven 25 gen 2008, 14:20
che divide per zero
Certamente; il costo di mana convertito di Ancestral Vision è zero:
203.3a. The converted mana cost of an object with no mana cost is 0.
quindi può essere impresso sul Panoptic Mirror pagando zero e tappandolo.
Sì, puoi giocare tranquillamente una copia e pescare tre carte in ogni tuo mantenimento; questo perché l'effetto del Panoptic Mirror ti consente di giocarla senza pagare il mana cost (che normalmente non potresti pagare, perché non esiste ^_^)
E' scritto anche nella parte di faq che hai citato:
It can be played if an effect allows you to play a spell without paying its cost.
Chiedete e vi sarà domandato
MessaggioInviato: ven 25 gen 2008, 18:49
Grazie oracolo, sempre chiaro e esaustivo, a sto punto dato che funziona come speravo (usare il mirror per fare un'ancestral a turno) mi permetto di chiederti se puo' funzionare anche se al posto del mirror volessi usare Izzet Guildmage.
MessaggioInviato: ven 25 gen 2008, 19:13
Se usi l'abilità Rossa di [card]Izzet Guildmage[/card] al posto dello specchio puoi copiarla fintanto che hai mana da spendere, ma solo quando uscirà da suspend (la magia deve essere in pila e in risoluzione per usare Izzet...)
Wizard ha scritto:
BIMBO ha scritto:
BOOOOOOOOM!
MessaggioInviato: ven 25 gen 2008, 19:46
ok quindi non funziona esattamente come volevo io peccato, usero' il mirror allora, grazie per il chiarimento alucard82 :)
MessaggioInviato: ven 25 gen 2008, 22:05
Mi è venuta in mente un'ultima cosa da chiedere, se io ho imprintato l'ancestral vision nel mirror, se l'opponent avesse in gioco uno Standstill, se io attivassi il mirror per pescare questo fa triggerare lo Standstill o no?
MessaggioInviato: sab 26 gen 2008, 11:22
che divide per zero
Sì; Panoptic Mirror ti fa giocare la magia in tutto e per tutto, semplicemente non ne paghi il costo di mana.
Quindi conta ai fini del numero di magie per l'abilità Storm, e fa innescare [card]Standstill[/card] e carte analoghe.
MessaggioInviato: lun 25 lug 2011, 20:27
Ciao, è possibile sapere come può intervenire [card]stifle[/card] su [card]ancestral vision[/card]? stifla suspend/la rimozione di un segnalino/altro?
grazie
MessaggioInviato: lun 25 lug 2011, 20:39
mprave ha scritto:
Ciao, è possibile sapere come può intervenire stifle su ancestral vision? stifla suspend/la rimozione di un segnalino/altro?
grazie
Suspend ha due innescate:
  • Togliere un segnalino all'inizio del mantenimento
  • Giocare la magia quando l'ultimo segnalino è stato rimosso
Quindi puoi con un singolo Stifle impedire la rimozione di un segnalino oppure impedire che la carta venga giocata (in questo caso la carta resterà esiliata).
MessaggioInviato: lun 25 lug 2011, 20:44
Con stifle puoi:
- Stiflare la triggered "all'inizio del mantenimento, rimuovi un segnalino"; serve per rallentare di un turno la risoluzione. Giocata discutibile, ma possibile
- Quando togli l'ultimo segnalino tempo, si innesca una triggered che dice "when you remove last counter, you can play A.V. without paying eccetera"
Se viene stiflata questa triggered, AV rimane esiliata con 0 segnalini tempo. Non avendone più da togliere (a meno di [card]clockspinning[/card]), la vision rimane esiliata ma non avrà più nessun counter da rimuovere per far triggerare nuovamente l'abilità
robgladiator ha scritto:
MessaggioInviato: mar 20 set 2011, 23:34
ho ancestral vision nel cimitero e quella carta che fa guadagnare flashback a un istant or sorcery. posso giocarla senza sospenderla?
MessaggioInviato: mar 20 set 2011, 23:38
Decisamente no.
MessaggioInviato: lun 14 nov 2011, 16:25
tre domande sceme:
_ anche se è stregoneria, con suspend viene giocata all'inizio del mantenimento giusto? non risolve durante la fase principale...
_ se ci fosse una magia che toglie segnalini da una carta (tipo c'è una vapira che rimuove segnalini dai permanenti, non so se esista anche una carta che ne toglie da magie), togliendo tutti i segnalini in un colpo si risolverebbe subito? .....magari è fantamgic..... : D
_ al turno di risoluzione della vision mi giocano [card]canto di orim[/card]...la magia trigghera quindi va in pila e si risolve cmq vero?
grazie
MessaggioInviato: lun 14 nov 2011, 16:35
1) si, nel mantenimento. Aggiungo che si può fare [Card]Quicken[/Card] + sospendere una carta sorcery come [Card]Restore Balance[/card] o [Card]Ancestral Vision[/card]
2)si, si risolverebbe subito. ci sono carte che cavano segnalini suspend in time spiral, per dirne una.
3)se canto di orim viene giocato prima che ancestral vision vada in pila, quest'ultima rimarrà rimossa dal gioco con zero segnalini sospendere e non potrà essere giocata(non so se, rimettendo un segnalino suspend sulla carta rimossa si possa rigiocarla il turno dopo)
MessaggioInviato: lun 14 nov 2011, 16:41
La vampira chiaramente no, ma puoi usare cose come [card]Jhoira's Timebug[/card]. Nel ciclo di Time Spiral (dove nasce la meccanica) esistono carte che fanno queste cose.
