Oggi è sab 3 ott 2026, 2:36
 Oggetto del messaggio: Nuova errata Mox Diamond
MessaggioInviato: mer 16 apr 2008, 10:26
Direttamente dall'articolo di oggi:
Mox Diamond
Mox Diamond was printed with the ability "When Mox Diamond comes into play, choose and discard a land card or sacrifice Mox Diamond." If you interpreted that ability under the modern rules system, you could play Mox Diamond, let the ability trigger, tap it for mana, then let the ability resolve and sacrifice it without discarding a land. It's one free mana! But under the rules system in place at the time Mox Diamond was printed, you couldn't do that. When the rules system changed, Mox Diamond got errata so it'd kinda work the same way. But that wording was a pretty significant functional change from how it was printed with regard to any effect that would put Mox Diamond directly into play.
Other cards from Mox Diamond's era, like Kjeldoran Outpost and Lotus Vale, got no-shenanigans wordings that prevented them from coming into play (and thus being tapped for mana) unless you fulfilled their sacrifice costs. Mox Diamond is getting a wording like that, to keep it as true to its era and its printed wording as possible. (It's still not exactly the same as the printed functionality, but it's closer.)
New Oracle wording:
If Mox Diamond would come into play, discard a land card instead. If you do, put Mox Diamond into play. If you don't, put it into its owner's graveyard.
{oT}: Add one mana of any color to your mana pool.
Il che significa che non bisogna più scartare una landa come costo addizionale x giocare mox diamond (x poi vederselo counterare -.-), ma la landa la si può scartare quando il mox è ormai già in gioco.
Buona notizia x giocatori di aggro-loam, white stax,...
MessaggioInviato: mer 16 apr 2008, 10:49
Riesci a linkare l'articolo originale.
Grazie
MessaggioInviato: mer 16 apr 2008, 10:55
ecco qua
MessaggioInviato: mer 16 apr 2008, 11:03
Ma quindi diventa un petalo di loto volendo?
Ah no, ora ho letto tutto
MessaggioInviato: mer 16 apr 2008, 11:07
se banane! magari! :-D
MessaggioInviato: mer 16 apr 2008, 11:09
Master of Ideas
http://www.wizards.com/default.asp?x=mt ... ature/453a
sostanzialmente nn cambia nulla se nn il fatto ke adesso mox si può usare come spell o x avere un artefatto in + nel cimitero (tipo x soglia o x goyf). Purtroppo xò nn si può fare il gioketto di usarlo come petalo...
Il mox adesso rikiede la carta prima di entrare in gioco, anke se viene messo in gioco tramite welder o tinker, mentre prima, quando era costo addizionale, questo nn accadeva. Se nn si scarta una terra nn entra in gioco, altrimenti era 1 mana x 0, tipo petalo.
MessaggioInviato: mer 16 apr 2008, 11:11
Edi ma quindi se ho capito bene adesso il mox diamond have to be a joke? :->
MessaggioInviato: mer 16 apr 2008, 11:13
Master of Ideas
ahahahahah :-D :-D :-D mirage sei senza senso...
no no, adesso mox nn have to be niente, è lo stesso legno ingiocabile di prima...
MessaggioInviato: mer 16 apr 2008, 11:18
Ricapitolando per me che sono scemo:
Con l'errata nuova non posso mettere in gioco mox-attingere mana e poi buttarlo al cesso senza scartare la terra,giusto?!?!?
Ufficialmente ho smesso con le figurine.Yeah!!
forse in vintage,... :-p
MessaggioInviato: mer 16 apr 2008, 21:08
Noooo
Puoi solo evitare di scartare la terra se ti viene counterato.
mrincubus ha scritto:
MessaggioInviato: mer 16 apr 2008, 23:43
...oppure castarlo e vederlo morire giusto per avere uno spell in piu o un artefatto nel cimitero.. SENZA scartare un terra (prima dovevi avere cmq la terra per giocarlo)
MessaggioInviato: ven 18 apr 2008, 22:20
siii sculo pure sulle regole loooolXD
MessaggioInviato: sab 19 apr 2008, 1:42
Nickname Cockatrice: ninjutsu
Quindi alla fine si puo o nn prende mana dal mox?
https://MeetAgree.com/it/ È genuina e è vicina
MessaggioInviato: sab 19 apr 2008, 1:45
se non scarti la terra non puoi prendere mana.
