Oggi è mer 30 set 2026, 19:25
 Oggetto del messaggio: [News] Cambio Regola Mulligan + Obbligo LayOut Board Video
MessaggioInviato: lun 29 giu 2015, 17:29
http://magic.wizards.com/en/articles/ar ... 2015-06-29
103.4. Each player draws a number of cards equal to his or her starting hand size, which is normally seven. (Some effects can modify a player’s starting hand size.) A player who is dissatisfied with his or her initial hand may take a mulligan. First, the starting player declares whether or not he or she will take a mulligan. Then each other player in turn order does the same. Once each player has made a declaration, all players who decided to take mulligans do so at the same time. To take a mulligan, a player shuffles his or her hand back into his or her library, then draws a new hand of one fewer cards than he or she had before. If a player kept his or her hand of cards, those cards become the player’s opening hand, and that player may not take any further mulligans. This process is then repeated until no player takes a mulligan. (Note that if a player’s hand size reaches zero cards, that player must keep that hand.) Then, beginning with the starting player and proceeding in turn order, any player whose opening hand has fewer cards than his or her starting hand size may scry 1.
...Then, beginning with the starting player and proceeding in turn order, any player whose opening hand has fewer cards than his or her starting hand size may scry 1.
The full details of how their cards must be laid out on the table in the video feature match area can be found below:
- Creatures must be in front of lands, and nothing can be behind lands.
- The library can be on either side of the play area (left or right).
- The graveyard must be adjacent to the library (player can choose which side of play area both are on).
- The exile zone must be near the library/graveyard and must be distinct from the graveyard.
- if a card is exiled by a permanent in play, the exiled card must be placed in proximity to the exiling permanent such that it is obvious that the two are associated.
- All untapped cards in play must face the controller of that card.
 Oggetto del messaggio: Re: [News] Cambio Regola Mulligan + Obbligo LayOut Board Vid
MessaggioInviato: lun 29 giu 2015, 18:15
se non ho capito male in pratica tutti quelli che hanno mulligato, dopo aver deciso di tenere la mano, possono fare scry 1.
giusto?
MessaggioInviato: lun 29 giu 2015, 18:36
Esatto. Immagino questo avvenga immediatamente prima che si possano mettere in gioco le varie leyline o le Gemstone Caverns,
MessaggioInviato: lun 29 giu 2015, 21:31
Nickname Cockatrice: Desolators
Da quello che ho capito la regola sarà vigente solo durante il Pro Tour (31 luglio-2 agosto), questo significa che neanche loro sono troppo sicuri e hanno bisogno di testare/limare questa nuova regola aggiuntiva. Io personalmente non so come prenderla. Prendere un mulligan (o più di uno) non fa mai piacere e a volte può pregiudicare una partita ma fa parte del gioco. La cura del deck building è stata sempre il punto di forza per ovviare a questo problema, io l'ho sempre vista e pensata cosi. Scry1 non cambia tantissimo le cose ma aiuta sicuro archetipi che prendono mulligan più di frequente a scapito dei deck più solidi che mulligano molto meno. Spanish Inquisition tornerà di moda? ...forse sto viaggiando troppo...
MessaggioInviato: lun 29 giu 2015, 21:47
Secondo me è una buona cosa, se un player mulliga ci sta dargli un minimo di spinta, non è che uno scry 1 ti cambia il game ma magari visto che a sei devi tenere mani già non ottimali ti da quella chance in più di giocartela
MessaggioInviato: lun 29 giu 2015, 23:00
Anche io la penso così... la vera domanda è: se cambia poco o nulla perche la Wizard ha sentito la necessità di fare una prova? di solito quando cambiano qualcosa nelle regole lo cambiano e basta, per la mia esperienza e da quanto ricordi è la prima volta che succede una cosa del genere.
MessaggioInviato: mar 30 giu 2015, 1:21
Nickname Cockatrice: Stinner
La Wizard mi odia :'(
La vita è lotta
Emanuel Lasker
MessaggioInviato: mar 30 giu 2015, 2:16
Ci fu anche la parentesi dei miniblocchi Lorwin poi cancellata e ripresa adesso...
@Der Wolf: pure io gioco lande davanti e "altro" dietro... che tristezza...
MessaggioInviato: mar 30 giu 2015, 7:34
Qualche giocatore di Dredge che si lamenta del posizionamento del cimitero? :D
Inviato dal mio GT-N7100 utilizzando Tapatalk
I tre assiomi della vita:
- Il Pauper è semplice.
- Berlusconi è onesto.
- Cicciolina è vergine.
MessaggioInviato: mar 30 giu 2015, 10:52
Giocato dredge tanto e non ho mai spostato il cimitero dalla pila dietro al mazzo.
Io cosa ho al cimitero me lo ricordo, se al mio oppo serve un aiuto immagino che siano azzi suoi :->
MessaggioInviato: mar 30 giu 2015, 17:32
Non lo sapevo, cosa è successo nei miniblocchi Lorwin? cosa cambiarono del regolamento?
MessaggioInviato: mar 30 giu 2015, 17:33
secondo me hanno paura di trassate. quando puoi mettere mano al mazzo serve stare attenti....
MessaggioInviato: gio 20 ago 2015, 17:18
Uppo il topic perché la regola del "nuovo" mulligan diventa effettiva dal prerelease di Battle for Zendikar!
Dicono che hanno avuto feedback positivi...
Link all'articolo ufficiale: http://magic.wizards.com/en/articles/archive/news/new-mulligan-rule-starting-battle-zendikar-prereleases-2015-08-20
MessaggioInviato: sab 22 ago 2015, 22:50
ottimo cambiamento che rende un pochino meno frequente morire da soli, ottimo in limited e utile nei costruiti.
MessaggioInviato: lun 24 ago 2015, 9:52
Riporto anche un articolo di Bryant Cook, grandissimo "stormatore", che considera formidabile la nuova regola.
http://www.theepicstorm.com/new-mulliga ... -zendikar/
